Help Looking For Shifter Stabilizer Bushing
SNOOP3223
MAZDASPEED PROTEGE
I took my car to the tracks and for the third consecutive time i broke some thing :'(. First i was just snaping the pass side motor mount, replaced it with a new stock one and put in motor mount inserts , went to track and snap , ordered solid motor mounts from street unit , waited 3 months for them droped them in went to the track and "tweek " instead of snap, went the motor mount on the pass side. Thats when i also discovered the my shifter was sitting kind of low and was making a "clunking " noise. and not to my surprise when i jacked the car up in the air i broke some thing !!(braindead the shifter stabilizer bushing !!!! i said joy at least it looks like a inexpensive piece . but the problem is i cant find it anywhere i even called mazda parts dept. and this guy thinks that i will have order the whole darn linkage assembly .(argh) wich by the way will run me about 300$(gun) i had noticed kartboy use to make a stabilizer bushing but now its discontinued . does anybody know where i can get a shifter stabilizer bushing please!!!!!
I am seriously done with racing this car i just want to fix it and be done with it . any help would be apreciated
nope wrong one , if you look at the install instructions the first pic from under the car the big rubber black block in the back with the holes in it ? thats the bushing i need . it holds the shifter linage assembly in place
Forgive me for my stupidity, since I'm not terribly familiar with the actual names of shifter pieces .. but if you're looking for the circular piece of white plastic that comes on the stock MSP shifter, I have one lying around in my 'leftover parts' box downstairs in the basement.
im listing a pic of what i need so that we can all get a idea of what i need sorry it took so long to respond ive been out of town
i rotated the pic so you can see the correct lay out of the part if you looking at it from under the car the shifter linkage assmbly is to your left the heat shield to the exhaust is below
found one got it from street unit .com im attaching a pic so everyone will know in the future
