SNike05 said:The number is important but what is more important is that all the numbers be roughly the same. TDRP I don't think you have anything to worry about your car is fine.
SNike05 said:pretty simple, remove your wires then unscrew the plugs one at a time. There is a comp. meter that you screw into where your plug goes. Then simply turn the ingnition. The meter will read the compression of that piston.
Obviously low compression is no good but 120 could be ok for the mp3, what I was trying to say is that his number are consistant so there is no immediate urgent problem.
