hello hello
so I posted about this a few months ago, but I have done a few things since, hopefully I can get a little input from you guys
from the beginning:
I had just finished my build last december and was running around in my car for 2-3 months with very few problems, mainly tuning.. I then managed to strip out 1st, 5th and reverse in the tranny so I parked it in my driveway until i could get a new trans to throw in it.. The car sat for about 4-5 months till mid summer and I got a new trans and put it in.. however, when i pulled the car into the garage from driveway, I found that my relocated battery in trunk had actually tipped over before I parked it and it was seeming out battery acid the whole time it was sitting there..
After doing the transmission and getting everything back together, I am able to turn it on and run it, new battery of course.. (sounds smooth as hell at idle and past.. to like 2500rpm)
I then tried running it on street and i couldnt get it past 3000RPM without it just firing like crazy..
SINCE THEN;
I have cut wire in trunk to try and put terminal connector back on good wire.. The wire INSIDE the insulation has signs of oxidation and corrosion.. so I decided to F the idea of the battery in trunk and place it back in engine bay, as close to the electrics as possible and getting rid of the corroded wire from trunk to eng-bay..
I still had same problem.. so i removed the alternator and took it to autozone for testing.. what do you know.. tested like s***. new alternator. (my car has been draining electricity and killing batteries for a year now, I think it was alternator whole time..)
anyways.. Now i have a new alternator, new battery.. I thought to myself, maybe i need to put good fuel in?? The car has been sitting for 6-8 months with no run time so I figured the fuel could be the problem...
since then;
I have been able to test it on the street and I am now able to enter 1-2 lb of boost and it is still backfiring a little.. I definately cant give it heavy load.. I should be able to hit 10psi no problem.. have before..
I cant seem to wrap my head around it..
bad wideband o2 sensor?
bad fuel? fuel filter? fuel pump is brand new...
bad TPS?
vac leaks?!
IM SCRATCHING MY HEAD SO MUCH ITS STARTING TO BLEED
help please
any suggestions/ideas are praised!
thanks
from the beginning:
SINCE THEN;
since then;
bad TPS?
vac leaks?!
help please
thanks
