Heating and A/C
cmx1204
Mazda MP3 Blue
Hey has anybody had any problems with their Heating and Cooling in their 2001 MP3's? I have already had my A/C replaced once which then tried to charge me for. And now my damn heater does not work and it is like 7 degrees. I only have 32,000 miles on my car. This should all be under warrenty?
coolant was the first thing I thought. But that was fine. Thermostat is the next but I would be damned if I could figure it out.
the thermostat wouldn't make a diference unless it was stuck open. You would still be able to feel heat in the top hose. The heater core mught be blocked or the flap hooked to the control in the center might not be working. Mine came off ( The Linkage ) and I had to get under and fix it. Be careful if it is off, the clip is ******* sharp.
(p5white)
