Headlights
Tommyr
2016 Mazda 3
My head lights are starting to get foggy. Is there anyway to clean them or do I have to replace the lense?
i used toothpaste and a terry cloth on my sisters sentra and they came out great. or you can use something like 3m headlight restorer
I used the Meguiar's headlight polishing kit on my old Grand Prix and it worked ok. I used the compound with a buffing ball chucked into my drill.
They didn't turn out perfect but were better and the light projected better.
My P5 headlights needed only a light polishing and then RainX.
i used 3M restoration kit last friday
worked quite well, although, unless you've had experience sanding, i'd recommend you stay away
the headlights look like trash after the first step, you may get pissed or impatient...
with sanding and polishing, you gotta take your time and work slowly with it -- don't give up!
anyways, it worked well for me and my headlights are crystal clear, onto project retrofit now!
