headlight haze question
ProtegePower
2002.5 MP5, automatic (sport shift)
Hey guys. I found the how-to on headlight haze, and I think I'll do it. Question though: is any of the haze (which I assume is more accurately described as oxidization) ever on the *inside* of the headlight? Thanks.
I know mine is on the outside.
alot of it is cuased by the road salt, sand and all the other crap kicked up when i drive.
If the haze is on the inside, sanding/buffing/polishing
won't matter. Replace them. Check out rockauto.com or amazon.com for CAPA certified replacements. Much cheaper than oem.
Hazing on the inside should not be an issue unless your seals have been compromised badly.
did mine, its ok, the only problem is if u sand alot ur not gona get ride of sanding lines......its not noticeable but if u look close since ur gona be doing it urself, it might bother u..but its quite easy DIY
