Hardrace Camber Arm Installed.
Chris_Top_Her
Contributor
San Antonio, Texas
'15 CX-5 Miata AWD
Installed my Hardrace rear camber arm today. Set them a few MM less than the OEM arm. I'll get an alignment and see what the total camber is but it shouldn't be too different. Also added a little tension to the front coils.
Nice Chris!
What kind of mufflers do you have there? I'm thinking about doing something like that myself. Do you thin,k that this setup is lighter then the factory muffler? How is the sound? Which mufflers are those?
Its corkspory and they are 8 lb lighter than stock. I had the tip extended out.
I have it at ~-3.5. Depending on tire wear i may reduce it but for now it handles nice and no rubbing
Not much interest, right? I wonder, how many are so low?
It is so much fun this low, I would not go back to stock.
It is pretty hard core, definitely is not for most people, but I enjoy it a lot.
I have learned how to drive it now, so no more bottoming out.
For example, when I take a turn, I get to a half a block away and only then the other car takes the turn.
....and I have herniated disk in my lower back and very close with my age, that soon will start with number 5.
