NeverSober said:
**********.com got the microtech working on a msp.....It is between 1,800-2k installed and tuned and what not................
And I believe they are the ones that contacted me because they couldn't figure it out on their own...
Our price is 1225 shipped for the entire unit with laptop software, harnessing, base maps, and everything you need to get started. It can run ANY injector and can even pair low impedance injectors for running dual fuel rails.
None of our cars can have a full ECU replacement as the necessary systems for ABS and the speedo and so forth can NOT be done by an EMS.
We have 3 cars running Microtech's right now, and a 4th is getting added shortly. The most powerful Mazda Protege5 known is running Microtech. It is a P5 in Puerto Rico putting out 540 horse...
If you've seen my videos you also know there are no cold start problems or issues running 550 primaries with the Microtech and my base maps for you guys.
Also, Microtech is known for being a bulletproof and reliable unit without reliability problems..
Lastly, there is no replacement of any stock sensors... so reversion is easy if you ever needed to do so... takes about an hour and a half to wire in and is as easy as installing a stereo.
Later!
Steve
