NCoppersmith
- Mazdaspeed Protege 3.5
For those of you running the Haltech E6x, how did you hook up your water and air temp sensors? Is there a reason why you can't / couldn't just splice the wiring for the existing sensors and have the stock ECU and E6x share?
Along that lines, does anyone know of a seller that makes a T adaptor for the water temp sensor? I'm getting ready to install my Haltech but I don't have access to an aluminum welder nearby. As far as the air temp goes, did you all just tap your intake pipe or something else? I have an injen sri that I was thinking I'd just have taken over and welded, but that's not as easy for the water temp.
