GT Spec trunk cage install help
orangeade
i got my trunk cage but didn't get any instructions with it. a little confused about the mounting points on either side of the stock subwoofer. does anyone have pictures of their set up and where specifically these two bars mount. also didn't get any mounting hardware for the main trunk bar at the very back.....anyone know what size bolts to use when mounting bar to body or are they existing factory bolts there.......again just got the bars and haven't taken anything apart for a good look. pics on the web on various distributor sites aren't all that helpful......thanks in advance.
figured out the rear most bar......that was easy.......still need pics of the bars that mount on either side of the subwoofer enclosure......anyone? am i drilling thru the actual subwoofer bracket? just want to make sure i get the correct mounting points.
Why can't you get instructions from the manufacturer?
AND what the heck is a trunk cage?????
I am almost positive you need to remove the sub deck to install it. i cannot remember at the moment how mine sits, but I already had the sub deck out when i installed mine and it didnt look possible to have both. I'll get you some pics of mine tomorrow.
Wont fit w/ sub box as far as I know. I didnt have my enclosure when i installed mine either. Also, its pretty easy to determine which side bar goes to what side......just sit them next to each other, and each one will have a slight angle to them. The bar angled down and to the right will go on the driver side, and the other on the passenger.....
These pics may help --> GT Spec trunk cage Pics
