Ground to fender measurements?
teddymac
'21 CE-T
'21 CX-5 CE-T
What is your ground to fender measurements?
With 225/55 r19's, CS springs and Bilstein Shocks mine is as follows.
Front 29.375
Rear 30.25
As measured vertically aligned with the center caps of the wheels.
Front
Rear
Visual
Curious what others are at, even stock suspension.
stock 2023 cx5turbo
driver side F 31.8125 R 32.375
pass side F 31.875 R 32.5
so you look like you dropped a couple inches+at least compared to mine...
Corksport Springs
OEM Dampers
245/45/20, full tread
Inches (cm)
FL 29 3/16 (74.14)
FR 29 1/16 (73.82)
RL 30 1/16 (76.35)
RR 30 5/16 (76.99)
