J johnjay5 Member Contributor : Protege 93|5 Jan 28, 2003 #1 Hey everyone, I seem to have a problem with my left driver side when I press the brakes. It makes a grinding noise in the axle or behind the wheel? Could I have damaged the cv boot or anything related to my axles? Thanks.
W WShade Member Contributor : '05 Subaru WRX - Red Jan 28, 2003 #2 Honestly, it sounds like you need a brake job.
A Apollo Member Jan 29, 2003 #3 Go in and check your brakes they are very easily taken apart, it is one bolt and the claiper swings up, check it out that just may be the problem
