GReddy Profec B Boost Controller
Captain KRM P5
Contributor
2002 BJFW, 2007 BK3P, 1979 SA22C, 2005 BK3P
Anybody heard of this brand/type of controller? Any good or bad thoughts on it?
I use the profec b. It's great. Probably one of the better ones you can get.
greddy is a execellent brand.
greddy is also the same thing as trust.
From what I hear, the profec B is the best electronic boost controller for the $. Supposedly it behaves more like a MBC...ie, not very erratic.
it rock steady because it uses a dual solenoid valve unit rather than single solenoid units. the dual solenoid allows more precise control over boost pressures and cuts down on the wear and tear. on a single solenoid unit, the one solenoind would have to cycle twice as fast to manage the boost pressure the same way a DSBC (dual solenoid boost controoler), im sure you can tell that 2 is better than one :)
$325 is about the typical rate for a black case Profec B. goe w/ the black, not the colored cases; the colord cases are hard to read the lables at night time AND the day time.
Plus you can adjust how FAST or Slow you want the boost to rise w/ the "balance" knob. i like the low and high presets, very cool. One preset for whoopin ass on the street, and another preset for whoopin asss on the track. if you turn it OFF, you can revert back to stock boost levels.
