KrayzieFox
- 01 MP3 Turbo
MAM replica would be great
Stock replacement please. My thunder manifold is on its last leg. I've had the damn thing rewelded for a third time.
yes there is a flex section in the exhaust. I just know that the piping that thunder racing used was thin walled.Do you have any flex in your exhaust? I'm not going to go to bat for thunder, but manifolds don't generally crack like that unless they are put through some serious stress.
Does a T2 turbine housing for an external wastegate even exist? Seems like if you want an external wastegate, then you also want a T3 flange, which means you are going to have a hard time fitting a turbo that big in the stock location, and you have a lot of custom work to be done anyway.
I think we need two camps here. Stock replacement people, and consequences be damned people. I vote for worrying about the stock guys first.
I'd delete the egr though.
Gotcha. Maybe I'll use 14 gauge or weld els rather than the 16 gauge I use on the downpipes.
Here's a question.... 304SS or 409SS? 409 is stronger and less likely to crack, but it won't take a shine and can even get a little rusty looking in some environments. It will never rust out it just won't look as nice. 304SS can be polished and is a great material, but I'm leaning toward 409 for this application. Plus 409 is cheaper![]()
+1 and already planned on just leaving the wga attached to the turbo tl hold the flap shutI'm ok with that. I want external wg with stock t2 location mainly cause I have popes dp, and external wg is so much more reliable
