hey Sub. i'm on the same boat you are. i want to retain both cats for emissions while still increasing power. i asked wagner about making a mid pipe w/ both cats so you could run a full header. he said it'd be about 450(w/ two random tech cats). the only issue we'd have to deal with is with the 02 sensor that comes after the 1st cat(stock itd be the precat post o2 sensor) because we'd need to have a longer wire attached to it because it would be farther downstream. that should be a simple fix. i personally like my idea of the twin cat midpipe. what do you think about that idea. and with running a full header youd definately gain more power and it'd be cheaper than getting three different exhaust pipes(the short header, down pipe and mid pipe)
