Gear removal
XoX1de
2000 Mazda 626 LX
How you guys remove gears from the primary and secondary shaft? Im about to remove my 3rd gear but the bearings are a b1tch to remove.
yeah I would like to know as well because I want to be able to rebuild my tranny when it becomes time
yeper had to take one to work to press them back on the bearing brace broke in half when the differtial went out. it was about to spill its guts when I found it lucky
Its probably a good idea to heat the bearing first before put it on isnt it?
Ya we baked them if i remember correctly helps with expanding but they shrink quick so doit fast these things are meant to take heat.sorry I cant remember the temp.
