Gb: Awr deep sump oil pan
Status
Not open for further replies.
Will everyone be able to make payment when the 5th person comes on? Once we have everything together We will need the full price of the pan in order for them to start the production.
Nice. I love mine! Everyone make sure you have at least a full set of motor mount inserts (if not full poly mounts). The square portion sits maybe 3mm from the frame on the passenger side and may hit with the motor rocking back and forth on stock mounts.
Is this a one time only thing or could there be another down the road. Also will this work with the 1.6 first of all if it wont then I wont be getting one.
brandon i have a 2.0l stock oil pan and i still have the 1.6l well if u want this weekend i can check if it fits? cuz im not sure? and im not if anyones tryed it?
BEWARE!!!!!.....THESE OIL PANS ARE NOTORIOUS FOR NOT BEING "SQUARE " OR "FLAT" AT THE TOP THE PAN MEETS THE BLOCK.....I am by NO MEANS knocking these oil pans ( i have one) but make sure when u speak to AWR you let them know of the issue....for a loooong time I kept getting a leak and took some time for me to figure this issue out.....again, I am but NO MEANS flaming, just giving you guys a "heads up"
Payment has been sent.
From what I understand this is the current list.
1.) Funkalicious21
2.)Perro del Sol
3. Mazdaspeedp
4.)
5.)
If we can get one more person, I will join the list to get this group buy going.
I still need to purchase new passenger and and transmission mounts before I get this. I'm thinking of getting SU mounts for the looks. =)
Just a reminder to everyone,
DO NOT USE THE PICKUP SPACER that's supplied with the pan. It smooshes the pickup too far into the pan and actually restricts oil flow, and is not needed. Beyond me why AWR even includes it.
Status
