gauge help!!
mazdaspeed 3 white
I HAVE SEARCHED LONG AND FAR AND HAVENT FOUND S**T. ok so i have the glowshift gauges. i bought the boost gauge, air/fuel ratio, and oil temp. now i know the boost tube connects to the bov. where do i connect the a/f ratio gauge?? can i even put that on my ms3? it said narrow band. and where do i connect the oil temp SENSOR for the ms3??? i have powered everything and it all werks just missin the connects needed.
The wire is white. You might be able to drill into the oil pan and weld a bung on. But i think that, that might be more work then necessary.
I had to send my A/F gauge back, Its is a narrow band gauge It will not work with our wide band sensors. At least thats what I was told. You would have to spend the big bucks and get a wide band sensor. The last time I checked , Glowshift didnt offer a widebnd guage. They did tell me that they were thinking about selling them but they wouldnt be as affordable as thier other guages.
No no you connect the af ratio to the white wire in the wireing harness. Ill send u the pic of the wire in the harnes. We already have a stock af ratio sensor why buy another
The MS3 has two O2 sensors. The one before the first cat is a wide band. Don't mess with it, it can seriously confuse the ECU. The second, between the two cats is a narrow band. You can tap into it with any problem. Too bad the narrow band signal is pretty useless, but it will make your gauge light up.
Any chance of getting those wiring pics out for general distribution? I will be coming into some money and a gauge system is pretty high on my list of wants (seeing as it would be illegal for me to get a catless down pipe...stupid EPA)
