future mods on my mp3?
you don't need it, but some upgrades would be beneficial (upgraded clutch, an LSD would be nice, and then you get into the BIG bucks if you get into higher boost...)
yeah, cause when you start thinking, "Hmm, i got a tranny that can handle more boost. let's turn it up!"
your motor goes KA_PUT
you have an MP3?
I have 2 protege5s that have crappy ECU's from teh factory, so, for an upgrade for me, i upgrade to what you have stock
But, if you further want to upgrade your MP3, yeah, full standalone will do that.
But, you WILL notice good gains with an intake, header, midpipe, and catback
in the long run, standalone costs about the same as all the other mods combined.
WOW. i've been checking through some of the sites i've found through the forum, JDM Sam's (www.*************.com), protegegarage.com, corksport etc. there is so much more out there than i ever knew. who is the best member to talk to on here that can tell me more about all the cool s*** available and what i need to do, and in what order, based on my wants? i appreciate all the info i received thus far, but i'm wondering if there's an engine nerd know-it-all out there that could head me in the right direction. especially now that i'm considering the turbo! i may have to re-think my whole game plan here...
P.S. to culridr: i was wondering if anyone would take my list and break down each part? i totally missed your post doing just that until now, lol! thanks...
What parts list are you looking for? If you have any questions about going turbo, make yourself comfortable in the Mazdaspeed Protege section.
Those guys have been pushing the limits, and breaking them with thier cars.
And considering the block is the same, it'll all be applicable to you too
99.99% of the questions you might have will have been answered before, so if you have one, just search for it (although it's not always easy to find what you are looking for).
Hey Lukie, the Split Second Air Fuel Controller is probably something you should look into. It's a "piggyback" unit, so it only allows you to do so much tuning. Your air fuel ratio can be adjusted in 500 rpm increments, and as stated before, only in open loop. When the car is opperating in "closed loop" it's going for the most efficiency in emissions/gas mileage. Jamesk did A LOT of research and communicating with Split second about using their AFC to tune a naturally aspirated car (the unit was originally designed to be used on the MSP only). He even has maps on here that you can load onto the software to get yourself a good tune to start with. Plus any local tuning shop should be able to hook it up and tune it for you without much trouble. Our cars run quite rich under full throttle situations and if you can lean it out a little, you'll notice big gains in power while still having great reliability.
I was personally going to go with this unit because of the price and ease of use. However, I had extra money and came across a great deal and ended up buying the microtech.
thanks pro and cul. like i originally said, i think i'm going to pay off my truck before i do any more major mods (then just get a nice-sized personal loan and do it all at once), so i have some time. i'll just keep searching through all these great threads and seeing what others have done and have to say about it! i appreciate the help...
Oh yeah, and Rahne, I agree with everything culridr said. Do some looking around on this forum in different threads relating to stuff you're interested in and you'll find so much info it'll take weeks to get it sorted.
One thing to keep in mind if any of you MP3 owners do go turbo though. Don't use the MSP ecu. The MSP's came with 4 wheel ABS and the ecu has those sensors integrated into the speedo signal. If the ecu is not receiving a signal from the tranny sensor AND the wheel sensors (which our MP3's don't have) your speedo isn't going to work. Buy a very cheap P5 ecu (without ABS) and get at the very least a piggyback Fuel and Timing controller.
-autoexe big bore throttle body vs mental addiction throttle body. Read some posts by LordWorm in the NA tune section about this stuff. A bigger throttle body strapped to OUR stock motor would most likely LOSE power.
-B&M vs corksport vs TWM short shifter. B&M is hard to find for our cars now. TWM is what I have and love it. It's a bit stiff at first, but once it breaks in it's a joy to use. It's also the shortest throw of any aftermarket shifter for our cars.
-fidanza flywheel vs unorthodox racing flywheel. Heard of several ppl on here with the fidanza, haven't heard anyting about the UR flywheel.
-I have the full set (4) of medieval's pullies and love them.
-unorthodox crank pulley vs medieval racing crank pulley. I prefer the stock size of the medieval pulley because it saves a ton of weight without any worry about not spinning the PS pump/ water pump/ alternator enough due to underdriving (which is what the UR pulley does)
-magnecor ignition wires vs nology hotwires are not necessary
-ARP head studs aren't necessary at this point.
-There is currently no supercharger kit for the protege. There are a couple running around, but they're all completely custom. I'm kind of looking into retrofitting a centrifugal style SC kit for a honda to fit our engines. It'll be at least another year though before I can have enough money to get serious.
-Never heard of the SLR chip. Where'd you see it. What does it claim? Where does it hook up?
-The motor mounts that put the least amount of vibrations into the cab are the stock ones from Mazda. If you're looking to reduce wheel hop and increase torque delivery to the ground, you can safely replace the front mount with a solid urethane mount and not have too noticeable vibrations. I noticed a BIG difference in vibrations inside the car after replacing the REAR mm.
Hope that helps. We all love to talk cars and share info with others, so don't be afraid to ask. On the other hand, like culridr stated a lot of the info you'll need has already been answered. Just look around and try the search function. Some times it gets you what you want, other times, not so much. lol
