outlander3001
Hi all. I am ready to install my fuel pressure sensor, but I want to make sure I have all the right part before I start messing with the fuel line. I am planning on installing a new hose and keep the stock hose untouched in case I need to put it back. Does anyone know what the inner diameter of the fuel line hose is coming from the firewall to the fuel rail? I looked at the service manual, but it only tells you how to disconnect the fuel line, not the size of the hose.
Also, I noticed that the stock installation does not use hose clamps where it is pushed over barb connections. Is this ok, or should I go ahead and put clamps in when I replace it?
Lastly, anyone have a favorite online shop with good selection of hoses, connectors, clamps, etc.? Somewhere I can get everything in one place?
Thanks in advance for the help!
