KrayzieFox
- 01 MP3 Turbo
You don't you just upgrade the pump for sufficent fuel delivery? The injectors are most likely not maxed. Plus if you upgrade the pump the rrpr would actually be able to have adjustments made. It sounds like your just running out of fuel.
Good point. With a better pump I could fully take advantage of the entire range of adjustability on the BEGi RRFPR. Injectors just came to mind first cuz they're really easy to swap.
