PINCUSHION
- 02 pro 5
sup, put a ze in my pro5 last summer, no probs, everything good. I have ram intake, obx headers, 2.5 " all the way back, repositioned o2 to behind the cat, upgraded fuel pump, pressure regulator, 330 injectors, everything ok. Here's my problem. I cut the maf off the 2.5 inch housing, mounted on 3" housing. Air/ fuel is screwed. I've been getting a lean burn and misfire code from about 5500 rpm. I thought it was a fuel problem, but now I'm skeptible.. I cranked the fuel so high it COULDN'T be lean, but codes cever went away. Could it be more along the lines of the crank/ cam sensors are getting out of sync, or maybe all sensor values are out of parameters??
Car runs great, but I hate that damn flashing light. There is no hesitation when driving, and no indication of an actual misfire, I'm lost.
