FS: New In Box Aeroforce Interceptor Scangauge
Status
Not open for further replies.
Gvr4-330
SOLD. Thanks!
Hey all.
I somehow managed to pick up 2 of these gauges, but I really only need one.
I paid $239 for this, but I'll let this one go for $205 shipped (and Paypal'ed to the US).
This one is still new in the box. I haven't even opened it. The one in the box is yours. The one in the pictures is so you can see what it looks like.
The lighting is red with and it black face, and black bezel. It's the best match for the Mazdaspeed! Now if only the ventpod would finally make it to production.
Rob
what exactly does the guage do?
never really heard about it before. sorry of its a dumb question.
It's a gauge that plugs into your OBD-2 port and can display a whole bunch of information directly from the car.
Here is the list of items it can display:
RPM
MPH
Knock Retard
Intake Air Temperature
Boost air temperature sensor voltage (post turbo)
Boost air temperature (calculated)
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor (A/F ratio, Lambda) on vehicles with factory wideband O2 sensor
Commanded Lambda and A/F ratio
Fueling status (open/closed)
Wideband sensor output current
Manifold Pressure in PSI (Boost pressure for factory turbo/supercharger applications)
Ignition Advance
Engine Run Time
Battery Voltage
Throttle Position Percentage
Engine Load
Direct Injection Fuel pressure
Calculated Horsepower
Instantaneous and average fuel economy
2 user configurable analog inputs**
Injector Pulse Width
Injector Duty Cycle
Valve Timing
I have mine set to show Boost and Wideband.
It has 2 digital readouts that can be fixed on one value each, or they can be set to cycle through different values. You can also set warning lights to come on when you exceed a value you set (only for one parameter though).
You can also see and clear trouble codes (DTC) and it has rudimentary 0-60 and 1/4 mile timers.
More information at the website: http://www.aeroforcetech.com/Mazdatech.html
Rob
Somebody buy this gauge!! 157.00 for it is a really good price and the gauge is absolutely amazing!! I dont know how I drove around without one to be honest.
ahhh my bad all I saw was total for this is 157.50 and didnt pay attention the rest! Its late ok! Get off me haha
Thanks! I hope the live.com thing worked and I'll get your gauge sent out as soon as I get back home after thanksgiving. I'll let you know!
Status
