After reding a few VTCS removal threads, i saw some members asking for the intake mani removal procedures, and no posts about that.
so i decided to make a how-to. and i named it "fs intake manifold removal" to make it simple to find....cuz i know some people DO know how to use the "search" button...sometimes just don't know what to put. lol
Please note, i'm an experienced, ASE cert. mechanic, but...... i'm going to try to make this as detailed as possible.
if there are any Qs, feel free to ask.
simple steps like removing the batt and the air pipes i won't bother with for sakes of saving space...lol...plus if you need help removing your batt or air pipe...you prob shouldn't be doing this....
ok.
tools:
10mm (deep and shallow)
12mm (d and s)
12mm ratcheting wrench, AND non-ratcheting.
14mm (s)
ratchet, screw drivers, one VERY long extension, small extension, swivel or u-joint, breaker bar, needle nose pliers
ok....let's begin with removing the batt, air pipe, and the strut bar. you should see this when you look from the driver's side fender into your engine...
next, you need to remove all the wiring that goes around the intake mani.
start with the a/c, ps, then crank and cam sensors, then coils, then a pesky lil one right above the alty, on to the 2 on top of the intake mani (control virs and vtcs), then the fuel press regulator solenoid, then the iac, then the tps. should look like this...
remove the pcv valve FROM THE INTAKE MANIFOLD AND THE VC.
next, we'll remove the fuel rail. you'll need the 12mm socket for the 4 bolts that hold it into place. BE BERRY CAREFUL, there are 4 plastic spacers that go right under the rail, and if you lose them, you're sol...they are black, and hide in places you'd never believe. i spent 3 days waiting on a replacement for one when i dropped it only to find it right under the cv joint...this was a very long time ago, so i learned from that.
here's the intake mani without the FR...
and here's the plastic doo-dah i was talking about....
ok.
tools:
12mm (d and s)
14mm (s)
