And your point with this comment is what?OK.
FYI..... thats why its call a pressure spring.
I don't see the oil pump is cavitating.
SUBJECT : Cavitation \
Cavitation means that cavities or bubbles are forming in the liquid that we're pumping. These cavities form at the low pressure or suction side of the pump, causing several things to happen all at once:
The cavities or bubbles will collapse when they pass into the higher regions of pressure, causing noise, vibration, and damage to many of the components.
We experience a loss in capacity.
The pump can no longer build the same head (pressure)
The pump's efficiency drops.
The cavities form for five basic reasons and it's common practice to lump all of them into the general classification of cavitation.
Vaporization
Air ingestion (Not really cavitation, but has similar symptoms)
Internal recirculation
Flow turbulence
The Vane Passing Syndrome
Vaporization .
Sorry, but I am going to jump in here for a minute....the cavitation occurs due to where the OE pressure relief valve (PRV) returns the unwanted oil...that is directly into the planetary gears of the pump....the bypassed oil is foamed somewhat causing the cavitation to occur. In removing the OE PRV and replacing it with an external unit the bypassed oil can be returned to the pan where the foamed oil will have little to no effect on the system......
Tom
I am still failing to see your point..other than trying to argue about something....that there is nothing really to argue about? (deadhorse
I was tryin to get an explaination on what he thinks was causing cavitation of the pump.
Foamy oil is a way just like he explained. I just hope that he blocked the stock PRV passage or the foamy oil is still gonna make it way into the pump.
This thread is confusing me... I have the TOGA high flow oil pump, and I have no idea what exactly TOGA does to the pump, but I did get much higher pressure than the stocker. Hot idle, around 700RPM, I get about 40psi, where on the stocker it was like 25. Hot redline is close to 80psi, stock pump was a hair over 55 IIRC. I know many things account for oil pressure, such as bearing tolerances, etc. But I wonder what they could have done with the pump to make the pressure higher? Maybe it could be done with the stocker?
Are you guys still accepting oil pumps? Everyday I keep seeing my oil pressure gauge reading lower and lower (checked oil level yesterday and it was only about 1/4 qt low) so I don't know whether it's my pressure sender or oil pump that's on it's way out (what else would cause low oil pressure?). I'll be installing a new oil pressure gauge soon but I still might try to get one of those improved oil pumps.
Yeah, it stuff like that I'm afraid of in which case it's good I'm saving up for a new motor. I'm going to try a new oil pressure gauge (need to get one anyway) and them follow up with compression and leakdown tests. Hopefully something will yield an explanation. Either way, if I do find myself with an extra oil pump I'll be sure to send it your way.Yes, we are still accepting pumps. Being in the middle of the race season the return time may be longer due to factors here in our shop and at the coating shop.
I hate to say but the problem may not be with your pump but with a main bearing that is starting to go..... causing larger and larger clearances and causing the oil pressure to drop...I would be very careful...if it goes could be catastrophic for the motor.....(shrug)
This is exactly what I'm going to be doing. I've actually had a sandwich plate for sometime now but the threading in one of the ports is messed up (why the company gave aluminum plugs with an aluminum plate is beyond me) so I have to fix it. I've already ordered a 1/8 NPT tap and some new stainless steel plugs and I'm in the process of getting some new gauges. Hopefully soon I'll be able to figure out if it was just that gauge afterall.I should also mention that I have a oil temp and oil pressure sensor hooked up to an oil filter adapter plate.
