Front/Rear Brake Change?
my car is a 2012 Mazda2 sport (manual Trans) with 56k miles and is a daily driver. I just replaced the front pads and took a a peek at the rear shoes. Quit a bit of effort to get the rear hub off - had to use the screw method that presses the hub off - But the rear shoes were fine and not even close to needing to be replaced. I would guess they might go to 100k miles...maybe more.
I've had that issue before.. Needed to pull the drum to replace a broken lug stud. Tapped with a hammer, nudges twisted and poked at it for 20 minutes before I realized I had the parking brake set. (engages the rear brakes)... So, laughing at myself reached into the car to release the park brake... And heard the drum fall off when the brake released.
Sent from my Nexus 6P using Tapatalk
