I've been wondering lately what my MSP would look like without the license plate on the front, but they are required by law here in Texas; I thought about it though, and started checking to see if all cars had plates on the front here in Austin. Suprisingly I found about 1 out of 5 cars have no front plate (could be all the college students, maybe), so I decided to give it a try.
Well the plate came off easy enough, as did the first bolt on the right side of the bracket, but the one on the left? It spins and friggin spins, but won't budge a damn inch. I tried using a screwdriver and a plastic shim (behind the screw driver to protect the bumper) and pry on it while trying to unscrew the bolt, and it still spins but won't friggin budge :mad:
Is there a nut on these bolts? The first one I pulled out looked self-threading (witha sharp-pointed tip), so I just assumed the second was also. The only thing I can think of is if there is a nut the bolt is locked to on the other side. I tried getting my hand up to there from under the bumper, and I found some sort of foam/rubber barrier just below the bolt blocking access from behind. Is my only option at this point removing the whole bumper so I can get at it from behind? Or is there a way of removing the upper grill to gain access?
What to do... this was supposed to be easy (argh)
