Front End Clunk
cpspeed6
2007 Speed 6
I found the where my front end clunk is coming from. Please have a look at these pictures and give me opinions of what the problem is.
Thanks
I have the same noise and its so annoying. It only appears when cruising through a parking lot, backing up and putting on the brake or below 10 mph. I took it to mazda 3 times and they couldnt dup the issue. F'n retarded.
Is this clunk when you turn the wheels all the way?
Because on mine i get a loud clunk that you can feel in the floor when turning the wheels all the way to the left.
From your pictures it looks to be your U-joint. If dirt got in the boot then it can cause damage. They aren't that expensive but get it fixed or you could have a disaster if it breaks.
Before i sold my Ms6, i did had that problem. It came from the driver inner tie rod. I took it to Mazda and it was under the TSB. They lubed the inner tie rod and it fixed the clunking noise.
