free way driving and rpm's
bwing2003
I drive on the freeway a lot and was wondering since most the time the rpms are over 3500, if it would hurt my car in the long run. I think we could of used a 6 speed.
I was just trying to point out the error in mica...
and i too think a 6 speed would be nice, but not likely to happen
yeah, sorry if i was kinda uppity...
but yeah, 6 speed...ooh baby. imagine the one from the MIATA in our cars...mmmm SNICK SNICK
Ooh crazy thoughts running through my head.... engine swap, with 6 speed... it could work.... maybe... i'll have to think about it when my brain is fully functioning lol
when you think of a 6 speed its not just adding on another gear..it shortens the rest of the gears to compensate..trust me..it will be the same way on the interstate..same speed..sucks huh?
I had a 6-speed and 5-speed Miata.
6-sp: At 70mph, turning 3300 RPM.
5-sp: At 70mph, turning 3500 RPM.
If you want good highway gearing, get a Crown Victoria.
the other gears to shorten but with an exact gear u can make the last pretty tall and great for crusing.....if u want lower rpms at speed get more hp :)
I would rather have a cruising gear but I love being barely able to tap the gas in 5th gear around 65 and being up to 80 so quickly gotta love the turbo being spooled up, makes for some nice fun.
thats true, its a nice daily highway setup, i can tap the gas crusing along and get ahead of anyone in a sec......although on long trips the gas mileage suxs having the turbo spoolin
"when you think of a 6 speed its not just adding on another gear..it shortens the rest of the gears to compensate..trust me..it will be the same way on the interstate..same speed..sucks huh?"
Exactly - 6 speed = too much shifting. On the highway if you want to pass you press the gas, instead of shifting.
are there any custom gear sets out there? I've seen one on that site(forgot the name but its refrenced sometimes) but it shortens gearing I believe. Too bad we cant swap tranny internals like honda b and d engines can.
Nope, won't hurt it. In fact, it is necessary to run that high to make decent torque. I was used to driving V8's when I picked up my first Protege and was bitching about it running 3500 RPMs at 70 and 3800 at 80 mph. I took it to the Mazda dealership and the master tech took me out for a test drive and showed me how to keep the RPMs high to make any power. He convinced me that I wasn't going to break it even though the engine sounded very loud. After driving for a while I figured out that I actually got better gas mileage at 3800 RPMs than 3000. That engine survived 12 years and 132,000 miles of high RPM revving including running for hours at 5500 RPMs with cruise control on. And the engine NEVER burned oil.
I was amazed that the MSP actually makes power lower down and can cruise the highways at "only" 3000 or so.
Keep the RPMs up and I bet you'll find out that the car is much more responsive to what you want it to do, even on the highway.
A better question for people on here is what is the RPM range for best torque?
Whover says a 6 speed will tun the same RPM's at highway speeds is wrong. It'll turn whatever RPM's they gear it at. Some 6 speeds are a real high overdrive gearing, that'll rev low. You could also have the ratios tight and the RPM's in 6th high- all depends.
You'd think Mazda's corporate parent Ford could donate the Getrag 6 speed from the SVT Focus (also used in the Mini Cooper S).
My wife has one and you want to run 5th for good throttle response on the highway. 6th is pretty sleepy unless you're really moving, but it cuts down on the noise of the motor, which is nice on long drives.
I think gearing depends on the engine characteristics too.
Now the Z06 can get away with a crazy overdrive 6th gear because of the torque. I think at 65 their RPMs were like 1500 or something like that.
