Found this intercooler
2003 MSP
Spearco on ebay Ok well that is the lonk to the intercooler i found. My question is.. It will fit right? (measurments are on ad page.) And if i bought it where could i go to get it put on? Thanks in advance.
Jon
anything will fit. I wouldnt go any longer than 31 inches however because you will encounter trouble with the fog light assembly.
I am using a 30.5 inch X 8 inch X 3 inch spearco unit from the same seller as that one.
It looks badass and will work well. Any performance store should be able to install it for you.
I would opt to do it myself however because it will be cheaper. All you need is a cutter, some u-bend pipes, silicone couplers, t-bolt clamps, a flange for a blow off valve and a blow off valve and you are set.
-B
So you did all the custom hard pipes your self for your car with that spearco intercooler? That is probably the nicest looking intercooler for the msp and probably has the most flow ,i might look into doin that.
