Forged Piston Info
LinuxRacr
Contributor
2001 Mazda MP3
Since more and more of us are doing this, time start a thread with specific info on the matter. I ask that all who post to this thread do thier best to stay on topic!!
Here is the info I already posted about the JE vs SRP pistons:
Here is some interesting info I got on Wiseco Pistons: http://www.porttuning.com/wiseco_pistons.htm
On that page here is what I found most interesting:
The forged piston industry uses two type of Aluminum alloys 2618 or 4032. The 2618 alloy is used for force induction applications. It has a higher density which makes it stronger, and heavier than the 4032 alloy. The 4032 alloy is used in natural aspirated(N.A.) applications. It's lighter than the 2618, because you need every mechanical benefit when trying to produce high horsepower numbers with a N.A.. Both alloys are run with 0.003" piston to wall clearance measure 1.300" from the bottom of the oil control ring.
Rumor has it that forged piston are noise, but that is not the case with WISECO forged pistons. Wiseco has had less problems in this area then anyone else. As you read above, most of the forged piston manufactures use the same alloy. Noise control comes from the actual shape of the piston. Wiseco machines it's pistons with a barrel on the piston skirt which controls piston slap better then anyone else. Customers have called back saying these pistons are silent, or they here a very low tick for about one minute. I have driven VW's for over 15 years, and all the engine I have owned have always been noise for the first minute. To reduce noise even more, LR Engineering piston kits come with an offset pin to reduce nosie even more. This is not a standard practice in the forged piston industry, because some customer will forget or get confuse during installation. Each set will include instructions how to install the piston, how to break them in, and what grit to use for honing.
The rings that come with each kit are made by Nippon in Japan which Wiseco is the distributor for in the states. Almost all piston and ring manufactures like Total Seal, JE, Ross, Venolia and others buy these rings from Wiseco. The ring thickness will be 1mm, 1.2mm and 2.8mm.
The piston pins are made out of Chrome-moly for extreme duty, and will be 3.5mm to 4mm thick. If you have had a problem with the pins breaking or coming out, that was due to flexing of the pin. When the pin flexes, it pops out the circlip. These Chrome-moly pins should solve that problem.
Make sure whoever makes your forged pistons makes room for the oil sqirters our engines have. Mine were chopped off by the pistons!
For those wanting to quiet down their forged pistons, you have the option of getting the skirts coated with Poly-Moly. A prominent company that specializes in this is:
http://www.swaintech.com
They also do the thermal barrier coatings to keep you piston domes cooler. Here are their prices:
http://www.swaintech.com/price.html
why weisco?? just cause its silent, how about durability...which is supposed to be the sheit?? i think i could deal with sound if the je pistons are better...thanks for the info by the way!
Keola,
Yeah, I was considering these next due to the "quiet" properties. From what I hear, JE's are "tha s***!" They are a little quieter now that I have about 350 miles on my new motor.
hey linux, since you're in america...ok well all of you guys are an i'm not, can you contact http://bmeltd.com/ about their pistons and rods. they are made out of 7075-T6 aluminium, are used in nascars etc...
the raw weight of 2618 has a density of 0.1lb/in^3, an ultimate tensile tension of 64000psi, and a hardness of 115 (on the brinnell scale).
4032 has a density of 0.097lb/in^3, an ultimate tensile tension of 55000psi, and a hardness of 120
and 7075 has a density of 0.101lb/in^3, an ultimate tensile tension of 83000psi and a hardness of 150
what does this mean to you (appart from a boring 3 minutes trying to understand what i'm saying)...7075-T6 aluminium will be much stronger than the others at only a tiny increase in weight....but then again it's all a case of give and take. you want strength, go 7075, you want just the lightest, go 4032.....imo ofcourse ;)
later
compression test??
Hey, does somebody knows what compression #'s gives 8:1 or 8.5:1 pistons?
I need to know this since im lowering the height of the piston to prevent another detonation to destroy my engine.
If 9.1:1 gives ~175psi....
Re: compression test??
it's not quite that simple to find actual compression ratio, although i'm sure someone could estimate (not me though). i believe dsm's at 8.5:1 are ~160's, but i'm not positive
Found an article, is states that in gasoline engines, it will be around 17-20 times of current piston ratio, depending on current temperature when doing the test. Diesel engines is another story.
so...
18.5 * 9.1 = ~168psi which is a good extimate
then
18.5 * 8.5:1 = ~157psi
18.5 * 8.0:1 = ~148psi
So, now i have another question: is 7:1 good enough or too low for our engines with turbo? will it have any issues?
7:1 is too low, 1g dsm's use 7.8:1 and have pretty much no power until the turbo is spooled, but they can run big boost numbers without as much fear of detonation. ~8.5:1 is usually considered the best daily driven compression ratio, as it has a nice compromise of having some low end power as well as being able to run high boost numbers, giving it plenty of top end. if you run that low of a compression, you are going to need a lot of fuel on the top end for the amount of boost you will need to be pushing to make power, and a pretty big turbo to flow the air you will need for the fuel. finding actual compression ratio requires knowing the exact capacities of each piston (done by using a dropper to put liquid into the piston) as well as some other information. as deposits build up, things start to wear, etc... actual compression ratios change, which is why i said it is a little more difficult to figure out actual compression ratios, although those numbers seem to estimate close.
I accually hear that 9.1:1 compression is best for off-boost response, but limits the amount of boost you can run.
