marathonman08
- 08 cosmic blue speed3
Ok, so i have been reading all the posts and read every forum for the speed3 and i can't come up with one straight answer of what spring and shim to use with the Forge BPV. My mods are Cobb SRI, Cobb AP running Stage 1.(soon to come: Cobb inlet, Cobb DP, Cobb FMIC, Stage 2 which will change everything) I know that Cobb doesn't tune the car with anything but the stock BPV but i like the Ping sound and I know with the right setup this thing is better. Can anyone out there give me a good answer??!!!
I have tried the blue with 1 and 2 shims and the red spring and my boost is WAY lower then stock on the same day same temperature outside...same gear. I was around the 19 -17 range with stock. With Blue and two shims i only spiked to 16 with it settling at 14... WTF? Can anyone explain this? Will the yellow springs compare to the stock BPV. Since Cobb tuned the maps with the stocker i think finding the forge setting that is comparable would be the answer. If not, im giving up and selling the damn thing.
