forge bpv sprnig and shim placement
mp5123
Contributor
silver 08 ms3
now i was messing around with my BPV and i read somewhere try doing shim spring shim with this cause any issues i did one run on it and changed the the pinging sound the forge is famous for to a more of a whooshing pulled out the spring and shims and the top shim had no metal flakes of any sort.
If you put a shim on top of the spring, it will block the relief port in the top.
ok so pretty much the nice turkey cobble whoosihing is just compression surge being not good
