[font=Arial, sans-serif]FPV Gets The Drift[/font]
[font=Arial, sans-serif]Ford Performance Vehicles will whip up another storm with its groundbreaking F6 Typhoon following the unveiling of an unofficial concept car at yesterdays ninth annual FPV Family Open Day. [/font]
[font=Arial, sans-serif]There is a tradition at each FPV Family Open Day for a group of volunteers from FPV and Prodrive to create a project car to showcase their abilities and generate some excitement among the visitors, said David Flint, Managing Director of Ford Performance Vehicles. [/font]
[font=Arial, sans-serif]This year, they have surpassed all previous projects. [/font]
[font=Arial, sans-serif]The team has created a specially-modified one-off version of the FPV F6 Typhoon sedan designed to tackle similar turbo-charged performance cars in the spectacular new form of motor racing; Drifting. [/font]
[font=Arial, sans-serif]DRIF6 features a lightweight chassis, racing cockpit and uprated version of its critically-acclaimed intercooled and turbo charged 4.0-litre in-line six cylinder producing more than 380kW of power and 700Nm of torque. [/font]
[font=Arial, sans-serif]We wanted to conjure up something unique and exciting for our new turbo fans, FPV Communications Manager, Andrew MacLean, says. [/font]
[font=Arial, sans-serif]Drifting is one of the fastest growing forms of motor racing in Australia and certainly one of the most spectacularso we let our imaginations drift in that direction. [/font]
[font=Arial, sans-serif]Unlike previous Family Open Day projects, DRIF6 is a fully-operational concept vehicle and Ford Performance Racings rising star, Mark Winterbottom, was involved in early development of the vehicle. [/font]
[font=Arial, sans-serif]DRIF6 was built by a team of dedicated engineers and technicians at FPVs Campbellfield facility with the assistance and support of a number of key suppliers, including Prodrive, Autotek, Castrol, HIS Hoses, Robinson Racing Developments, Revolution Racegear and Dunlop. [/font]
[font=Arial, sans-serif]At the heart of the DRIF6 project is an upgraded 4.0-litre turbo-charged in line six cylinder engine with modifications made to increase the efficiency of the turbo system and to boost power and torque. These include a significantly larger intercooler with a revised induction system that features a ram air box taking air from where the fog light is normally located on the production car, a hand made plenum manifold replacing the individual inlet runners, a unique engine management system calibration and three-inch straight through exhaust system with side outlet. [/font]
[font=Arial, sans-serif]The transmission has an upgraded Tremec T-56 close-ratio six-speed gearbox and AP racing twin-plate clutch driving the rear wheels through a locked differential. [/font]
[font=Arial, sans-serif]The braking system includes the optional Brembo brakes available on the F6 Typhoon with 355mm front and 330mm rear cross-drilled and pillar ventilated rotors and six-piston monoblock front calliper and four-piston rear calliper. It has been modified especially for Drifting with high quality braided hoses, a brake proportioning valve and a WRC-style hydraulic handbrake. [/font]
[font=Arial, sans-serif]The cockpit of DRIF6 has been stripped and replaced with world-class MOMO racing seats and racing harnesses, MOMO steering wheel, MOMO gearknob and a variety of ancillary gauges by VDO and Autron. These include a monster VDO tacho on the dash located in line with the twin-pod sport gauges that display oil temperature and turbo boost pressure, A-pillar mounted gauges to display volts and cabin temperature and Autrons latest high-tech tyre-press monitoring system located at the base of the Interior Command Centre. The cockpit also has a racing-style roll cage. [/font]
[font=Arial, sans-serif]The DRIF6 is a concept car designed to showcase the enthusiasm and expertise of FPVs engineering operations. There are no plans, at this stage, to participate in competitive events. [/font]
[font=Arial, sans-serif]The FPV Family Open Day featured more than 300 of the best-loved performance Ford vehicles on display from car clubs across Australia and attracted approximately 10,000 visitors [/font]
[font=Arial, sans-serif]DRIF6 Specifications[/font]
[font=Arial, sans-serif][/font]
[font=Arial, sans-serif]Body:Lightweight F6 Typhoon, Four-door sedan
Engine:Turbo-charged and intercooled 4.0-litre DOHC in-line six cylinder
Turbo charger:Garrett GT 35/40
Induction system:Hand-made twin-plenum manifold with custom three-inch pipes from
turbo charger and intercooler. Ram air intake from lower front bumper into K & N pod filter
Engine Management System:Customised calibration
Exhaust:Stainless Steel three-inch straight-through with side outlet
Intercooler:Front mounted 600mm x 300mm x 75mm
Power: Aprox 380kW
Torque:Aprox 700Nm
Clutch:AP Racing twin-plate
Differential:Locked rear differential, 3.73:1 final drive
Brakes:Cross-drilled and pillar ventilated 355mm x 32mm front and 330mm x 28mm rear rotors with Brembo six-piston monoblock front and four-piston rear callipers. HIS braided hoses. Pull-operated hydraulic handbrake with Tilton brake proportioning valve.
Seats:MOMO
Steering wheel: MOMO
Harnesses:Four-point MOMO race harnesses
Battery:Optima; mounted in rear of cockpit with central-mounted kill switch
Gauges:VDO monster tacho, Autron tyre pressure monitoring system
Wheels:19x8 inch five-spoke alloy in Dark Argent
Tyres:245/35 ZR19 Dunlop SP Sport Maxx
Lubricant:Castrol Edge 0W-40 [/font]
source:http://www.worldcarfans.com/news.cf...try/acf/ford/ford-fpv-drif6-concept-australia
