QUICK NOTE TO EVERYONE:
I just realized that I used teflon tape on my oil fittings: BAD IDEA. I wasn't thinking. Hot oil will melt and render useless the teflon tape. I already have some high-temp anti-seize that is safe for sensors, so I am using that. I have taken all my oil fittings out. And of course while doing so the wire that attached to the standard oil pressure sensor broke off, so now I have the fun of repairing that, and when I was disconnecting the gauge oil pressure sensor, the molex connector broke on that... and  I found out that the spot I tapped the downpipe for the EGT probe is right in the way of the coolant return line on the block... so all in all it's been a bad morning.
