Very good! I'm glad to see that someone understands the bracket concept that I've been thinking of. The bracket will have to be a thin sheet of aluminum or something because it'll be a tight fit around the light.
Protege5Gurly said:
Dont use too much though..A really hot mixture wont harden and cure correctly....but it will get real hard real fast.It just wont hold up like it is supposed to.Protege5Gurly said:
Proof that Mountain Dew is a requirement for proper automotive fabrication. lol.Dexter said:
yeah, i shoulda mentioned that too...dont use TOO much...if u do, its kinda like spraying cold water on a hot pan...not good(causes warpage) but in the case of body filler it causes it not to adhere to the surface its on and crackes inside it also.ForceFed said:Dont use too much though..A really hot mixture wont harden and cure correctly....but it will get real hard real fast.It just wont hold up like it is supposed to.
Matt
(wink)protegeV said:yeah, i shoulda mentioned that too...dont use TOO much...if u do, its kinda like spraying cold water on a hot pan...not good(causes warpage) but in the case of body filler it causes it not to adhere to the surface its on and crackes inside it also.
(thumb)vodapas77 said:Proof that Mountain Dew is a requirement for proper automotive fabrication. lol.
Epoxy? What do you mean?dominoy2k1 said:have you thought about using some kind of epoxy to make the covers? maybe urethane?
Yeah, well technically its the plug. The mold is phase two.protegeV said:he could...but what he's making now is just a mold.
