Hello,
I have 2006 Mazda3 GT. 120k Miles. About 3 weeks ago I was driving with about 40-45 mph and suddenly car jerked. I though I rolled over a rock or a branch but then I noticed an AT light illuminated for a split of a second. It went away and car continued normally.
This happened a couple more times that same day.
AT sometimes illuminates even when sitting on the red light.
I checked the ATF and the level was low.
Since then I have drained an ATF and cleaned the pan. Replaced the filter and refilled with Mazda ATF M5 (M-V). Now the level is right.
The problem did not go away!!!
I am guessing for some reason there is some kind of malfunction and that is why AT illuminates and then it switched to the safe 3rd gear. That is why it jerks. The AT does not stay on and my CEL is not on either. So I cannot pull any codes. I tried but it just says no codes.
The ATF that I drained was pretty dark. I did not do a flush but I am going to drain again and refill again. May be even replace a filter again. So I will bring it to a much cleaner condition. I can do drain and refill even once more to make sure the ATF is nice and red. This is an easy procedure and I don't mind it.
Any suggestions what else should I check? Can it be that my sensors are going bad? May be not quit bad yet? Any connection issues?
Do you think this can actually be the transmission going bad? The car drives nice and smooth otherwise. I tried to drive in manual and it can do that too.
Any suggestions are welcome.
