foggy windshield.
Karma_hunden
'04 protege, then '05 mazda 3i, then '06 MS6 GT, now '10 RX8 R3
Alright so I know this has had to happen to all of ya. Ya know, when you get in your car and all the windows are all fogged up...sucks. My guess is because the inside of the car is cooler than the outside. So i turnt he heat on and turn the thing all the way over to the right so it puts the hot air directly on the windshield. But most of the time I get no results. I want to get one of those water absorbing cloths...but still, it pisses me off. How do yall deal with this?
just wondering...
hmmm i don't have that problem really, and if it does happen it usually clears up pretty quickly... i would check to make sure all your doors/trunk are closed as well as the sunroof... sounds like you may have a bad seal or something if it happens all the time.
do you leave the car's AC/heater in "fresh air" mode before shutting off the car? if so that maybe the problem
nah, it doesnt happen to me all the time, but since i live donw here in Florida, sometimes we gte a lot of humidity which leads to that. Hm, i really dont use the fresh air feature at all...dont think that might be.
If you put the system on defrost, it will put the air intake on fresh or outside air and also turn on the compressor. This should clear the windshield in a few seconds on high fan speed.
