Fog Mod Finished
05maz3subd
Mazda 3 lava orange hb manual
it took a while because i kept messing up, so basically heres how it went...... I started off moving and cutting the wires under the passenger dash board, the first attempt disabled the high beams and remote key lock. the second try enabled those 2 but disabled the 4 ways and the wipers, so i just said screw it, well i just put the wires back in their place by cutting and re-soldering them to OEM, then i found the correct mod where the fuse box in the engine bay needs to be changed. I took an 18 gauge wiring and tapped off the the red and black wire plugged into the plug inside the steering console, then i took the relay and connected it and tapped out of that and got it to work, I had stock fogs, they sucked, got LED fogs, they sucked, just got 4100k from auto zone, the silver somethings, pics will be up soon... hope they are brighter, all that hassle for something so simple
