fog lights
Epix4Lyfe
2002 Mazda Protege5
does anyone know how to change the fog light bulb? i've been tryna do it but don't really know what i'm doing
Well firstly, you have to remove the fog light. It's easy(er) to do with the bumper removed.
I was able to do mine without removing my bumper... I unscrewed it from the bracket from underneath my car.. It wasn't hard to do.. Once the fog light is off, there are two screws behind the light that you need to remove to get to the bulb..
There is one bolt that holds the bracket on, just remove that one and the whole thing will come out. There is a plug clipped to the bumper that you have to unplug and you are set.
The screws are soft brass. Be careful. I had to drill one out and use RTV to seal up when i was done.
you do not need to take off the bumper for this.
there are 3 screws on the bottom plastic that you need to remove, then you can get to the fog light bracket. i had to use a lot of pb blaster to get the rusty nut to move here, that is why it is all orangy-brown there.
that is the only nut/bolt you need to deal with to remove the fog light. the bracket has 3 bolts, but that stays on. the fog is only on with one bolt to the bracket.
now, dont just pull, you have to unclip the wires first.
the little blue thing is how the wires are clipped and tucked up behind the bulb. you can use a screwdriver to push this in. then from behind, unclip and you are set to remove the fog light assembly.
once it is out, you have 2 screws to deal with. they are on the back here.
these are the soft brass screws. every fog light i have touched, at least one of these screws brakes off the head and you need to drill it out. be careful, but that wont matter. once you get the screws out, you may have some time getting the 2 halves apart. it takes a bit of wiggling, especially if they have never been replaced before.
now, it is pretty straight forward on replacing the bulb.
hope this helps.
also, im sure this info is in the how to section.
go here for steaths quick links for lots of info on fixing your p5!
http://www.mazdas247.com/forum/showthread.php?t=123715657
