FML right?
My last 4 sets of Arias pistons did the exact same thing on cylinder #4. I run CP now.
haha funny this was a set of yours also. So you recommend CP over wiseco?
Would it be safe to run stock compression ratio when using meth? Don't really have a way to mess with timing.
Edit: Wouldn't I have known if detonation was occurring? I thought they always talked about "pinging" sound. Either way I've already decided next rebuild will get meth.
Let me get this straight, you want to run the 9:1 compression without timing control?
Get ready for another engine build... Knock is VERY hard to hear on the FS, you need to be running some kind of standalone even with methanol. At the very least you need a knock detection device.
CP pistons are the best pistons you can buy for the FS.
would the ssftc be sufficiant to run 15 psi on stated compression ratio?
the reason i ask is not because i want to cheap out on my build but i want a safe tune till i can afford a standalone.
Try it and find out! (eek2)
I ran 15 psi, as did the previous owner, for quite a while. 9:1 compression, Arias Pistons. No problems. There is no standard for failure, no whp number, no psi, etc..
I think we've all seen people running ~14psi on the stock turbo, and even stock block sometimes, with no immediate ill-effects. I'm not discrediting what Max is saying, I just don't see why 15psi from the gt2554r @ 9:1 compression would cause problems based solely on that.
Also consider the importance of proper oiling.
Get a DocB modified oil pump and external oil press adj. for these high boost builds.
Its a very worthwhile precaution.
Hmmm...this sounds a lot like your engine issues. Check the plugs?
15psi on gt2554 is wayyyy to hard on the turbo, yoour working the turbo out of the choke line. not good!
i'll go with 8.5:1 again that isn't a problem. I was just wondering because before i was told to retard the timing, but if using meth to advance? That why i asked about 9:1 on meth.
The whole reason you run lower compression is so that you can up the boost with less risk of detonation. You will make more power off boost with higher compression, yes, but when on boost you will be able to run alot more boost safely and make more power that way. The methanol is just an aid in helping keep the engine safe while you push the limits. It's not a band-aid for a lack of engine management. I've seen TONS of people blow their engines while running methanol, and they sit there and scratch their heads and wonder why. You need some way to be able to control your ignition timing.
So, to answer your question, 9:1 is fine, but even with meth, don't expect to push past 18-20psi and expect it to be safe. You will detonate unless you pull timing, but then you'll be pulling so much that it would put out more power if you ran more timing with less boost.
I had my engine running 8:1 compression last season, and I easily stuffed 32psi in there with meth. I didn't like that though, off boost it was a slug. The engine only put out about 100hp until that turbo spooled.
So, it's a trade off. Figure out what you want to do. If you want a mild street build, 9:1 is great. If you have illusions of running "big boost" like some of us do, that's not gonna work.
Garrett Reps told me over the telephone that the stock turbo can be ran at that psi level (15) with no problem, although outside of it's "peak efficiency". They had no concerns at all. Take into consideration, that I only run 12 max now, but still, while it's not a good top end or high psi turbo, it can in fact take it.
Maxx, I don't plan on going any higher than where I'm at. 15-16 psi is where its going to stay at. I just want it to be a fun daily that still gets decent gas mileage. With my other project I'm going all out with a goal of 25-30 psi on a hx35/40.. but thats another story. I'll deal with that once I figure out what to do with the MSP.
All I want to do is run the 15-16 on the tater safely so I don't have to keep tossing money into it. What would you suggest is the best set up for that?
hondaeat-r, change your settings this thread is only 2 pages for me :p
yes 15psi is no problem from 2500-5000 rpm, hell you can run 20psi on that range, but when u are near redline with that level of boost it will kill the turbo fast. I followed the compressor map to figure it out, so with a boost controller like avcr, you can actunally tune the boost by effency island.
2000rpm 10psi, 3000 25psi 4000 20psi 5000 15psi 6000 8psi, you know what i mean.
