Smitty1017
- 2003.5 Mazdaspeed Protege
So, I am currently replacing the clutch/flywheel/LSD on my car and ive had the tranny off for a couple weeks now and its been sitting around waiting on parts. I finally got everything today and decided to go pull the flywheel, but I cant for the life of me stop it from spinning. Is this something you need a second person for or what did you guys do? i tried a second jack raised against the teeth, a prybar against the teeth, and etc..the only problem is those bolt are on really good and if i need to hold something with one hand its going to be tough to break the bolts. the impact at max psi wont break them either, although my compressor kinda sucks so that may be the issue. Is there some kind of tool I can use to do this?
