I am at the point ready to remove the Flywheel and the crank pulley....And I know the flywheel is balanced with the engine....How do I mark this for reinstallation after the motor is back from the machine shop...Or does it only go on one way?
Is there an alingment pin?
Will the machine shop remove it if there is?
I just want t make sure these go on how they should.
Same with the Crank....Does it need to go back on exactly in the same position in relation to the Crank?
My Rebuild manual does not mention this or my bad eyes keep passing over it.
Any Help will be appreciated.
