So I spent the last week and a half prepping my car for the Track Attack event today at Academi.
Had a state inspection done last week, found out one of my pads are at 1.5mm to the backing plate(driver side outer), all others had 4.5-4.6mm left. The driver side rotor was worn just below minimum spec as well at 0.817in(discard spec is 0.830). Passenger side was 0.857in, so still had some left to go. Brand new rotors at 0.912-0.915 roughly.
Slide pins were seized in place pretty badly, probably took about 30lbs of force to free the sliders? I cleaned them up and regreased them with the Permatex Ceramic purple stuff I used before.
So I ordered some Hawk HPS 5.0 pads through work, since they're dirt cheap($50) along with new rotors. A lot of people seem to praise them for their initial bite and all that jazz.
I ******* hate the feel of them. Requires much more effort than the AX6s did, they seem to lock up easier, yet don't stop the car as quickly from higher speeds? I have to reserve full judgement of them until I actually run an event. Initial bite is nowhere near as awesome as the Carbotechs.
Also, when I went to do the brakes, the slide pins were freaking sticking again... after 200 miles of daily driving!
The purple s*** turns into sticky chunky blobs of crap that gum up the pins. Both the solid pin and the one with no rubber "sleeve" were stuck pretty badly. I ordered a bunch of new caliper pins to replace all of them with solid parts so that swelling of the sleeve can't occur.
I'm currently running Sil-Glyde based on a LOT of reading so hopefully that stuff does the trick. The purple crap is rated to 3000F, but that's evidently a load of horseshit, and others have had the same experience too.
I also had all my tires flipped on the rims because of outside edgewear. Academi is supposed to be pretty hard on tires, so I figured I'd kill off my old ones there.
Fast forward to yesterday, I pulled my second set of full tread/near brand new RE71Rs on the same style 15x7.5 TRM C1s out of storage to mount up... because of the 100% chance of rain today.... didn't want to be hydroplaning down the straight on 3-4/32 RE71s.
Carbotech dusted fronts vs clean/unused rears...
All new:
And about 5min after swapping everything on, I got a text saying the event was cancelled/postponed :diaf:
Frankly I'm glad, because setting up timing and scoring would suck balls in a torrential sideways downpour.
So next event probably won't be until 9/18 at ACU-4. I have a ton of brake caliper pins, new boots, and also a bunch of caliper piston dust boots on the way(I also found one dust boot with a hole in it when doing the brakes) to take care of before then. I'll also be able to see if the Sil-Glyde did anything or not.
