FK Auto Projectors
I believe that screw actually aims the beams to the left or the right. You have to turn the screw quite a bit to see a noticeable change in the aim.
Question for you: Did your headlights work properly when you installed them per the instructions, or did you also have to modify the wiring like I did?
Hi inspekt, been a long time!
I finally had the headlights put on with little to no idea on wiring and taking the whole thing apart. Your guide on the silver build Page helped quite a bit so I thank you for that!
With your headlights, do you have a screw that has L & R engraved up the top? I'm a bit wary of twisting this screw since I have no clue as to what this does. Any idea what twisting said screw does? Would be a god send if it converted the headlights to RHD hehe.
Been using 8k HIDs with the headlights and it looks awesome. But as per your suggestion it is aimed low, In line with the rear number plates of the car in front. I'll upload some pics when I can!
I had help with the wiring from a friend who happens to be an apprentice electrician. I'm 100% sure that the wiring had to be modified. We had to salvage the stock wires and carefully make sure that every connector from the FK lights were connected. Although the lights work, for some reason the right headlight won't turn on if the car is idle and I turn the headlights on first then the ignition.. But when I turn the headlights off and on again once it's the engine has started then the right projector works just fine.
I've been meaning to take it to an auto electrician sometime in the near future. Will listen more attentively and post the exp here.
Thanks for your input btw.
Looks awesome RSun!!!! That is one hot 2!
Thanks inspekt!! I like it a lot more with the foglights. The bulbs I got are an off white though so it kinda looks funny with the LEDs which are like bright white..which bulbs are you using?
