First time CDFP internals
I need a bit of help with this:
How do I get the retainer off the stock internal's shaft?
TYVM.
It's allright, I figured it out. I thought it must be like a valve lock, in that a tap on a socket the size of the retainer would release the lock and, I was correct.
Need one more Q answered...How do I get the little button (stock-style retainer) back ON the retainer? And it's bevel side OUT, right?
Here's my answer I figured out after some head-scratching: I pushed the shaft up as high as it would go, slid a 14mm box wrench under the retainer, laid it between my slightly open vise jaws, with the wrench overhanging the gap, then putting the button on and smacking it with a deadblow hammer. Went on right away, doing that.
This is hilarious, I'm a one-man thread, here, lol
nice little bit of info. I never had to use the stock retainers as the KMD kit came with it all, just used the stock spring. good s*** to know though
I like the stock retainer, light, pretty much indestructible and the pressure against it can only make it tighter over time, rather than loosening it.
Lots of conflicting/absent data out there, I must admit. Is it 40 lb/ft for the cap, or 60, or 78....is it fuel to lube or oil, which way is up on the stock retainer button, blah blah, blah.
I used 50 lbs because it's obvious from the fine threads on the cap, 78 is WAY too much, 40 is what AWE recommended but, that's a VW pump. 50 passed the TLAR test.
I lubed everything well with 10W30 synthetic motor oil, figuring that first start up might just be the deal-breaker. Those tolerances are pretty tight and something more shear-resistant and "lubricious" than gasoline should be in there right off. Gasoline should dissolve the motor oil pretty quickly and not cause too much grief downstream, imho, of course.
Similar Threads and Articles
