First Post + question???
The factory wires are much to small to handle the 300/2 you are using. They will need to be upgraded.
Basicly you have to take of the boot on the door jam for the wires going into the door then disconnect the outer molex then pop the iner one back in and then drill them out in the same spot without killing ot cutting any wires you might need. Then you have to run the wire though both molex and boot then put everything back together. It takes a few hours and there is a definite risk of killing something.
