They have not done anything....as well as any recalls, or computer software updates for the onboard systems.
a car wash and vacuum.
I would sue if they car washed without permission.
. I always turn it down too.
Firstly, go to your "Vehicle Status Monitor" under “Applications” in your infotainment screen and select "Maintenance” to display the maintenance list. Check if you have "Flexible" setting under "Oil Change" which is supposed to be the default from factory. You can use the miles left on your oil life as a guideline for your first oil change. Follow the "Flexible" oil change interval which is up to 7,500 miles (10,000 miles for 2016(.5) CX-5) or 12 months whichever comes first. You can take your CX-5 in based on "Oil chang due" message with a wrench indicator from your "Flexible" oil change monitor, or do it early before the message displayed as your like. I'd keep the moly-rich factory oil in there for at least 5,000 miles within a year and do the first oil change.
Make sure to reset your "Flexible" oil change monitor with ignition on without engine running. Most Mazda dealers won't do this for you as many don't even aware this feature. If you see 7,500-mile oil life, it's been reset!
Be aware those "free" oil change offered by dealers. They'll use the cheapest bulk oil they can find. So do ask and see if you can have better options such as Mazda 0W-20 moly oil which is only $10 more from my Mazda dealer for oil change. The only goog thing doing the oil change at dealers is they "normally" would use OEM oil filter with new drain plug washer.
What does touchless mean (apart from not touching it!).
It washes the car without the spinning mits via high pressure washers and several passes instead.
True, touch will actually clean the finer stuff that the touchless leaves (just look at your dirty windshield after a touchless wash, chances are you will still see the wiper line), however touch wash should be done properly by hand. There's a reason they call the automatic touch washes swirl-o-matics (swirl marks and scratches galore!) My car is scratched to hell from using those kinds of washes earlier in the car's life.![]()
Same thing with the touchless automatic washes too. Touch will always work better to clean the car, but only when done properly by hand. Automatic touch car washes (rotating mits) are just a recipe for scratching and swirl marks.Ah, OK. Not seen one of those here but I do have a pressure washer. It won*t clear heavy dirt, it leaves a murky haze.
Exactly. However, my dealer is far away from me and I would rather not take it there. That's why I wanted to find a mechanic in my city.If as the sender states that he is NOT car savvy then, he doesn't want to practice on the first oil change. Just suck-it-up and take his new CX5 to the dealer. The first service is a general inspection for leaks etc. Ed
What does your "Vehicle Status Monitor" say on your oil life? I wouldn't change the factory oil until at least 5,000 miles of usage.Oh, what the hell. I bit the bullet and made an appointment for tomorrow with my dealer. We'll see how that goes. Still, I would like to find a local shop and start developing a relationship with a local mechanic.
I don't get a message, if that's what you're asking? No blinking light, no nothing.What does your "Vehicle Status Monitor" say on your oil life? I wouldn't change the factory oil until at least 5,000 miles of usage.
So you're recommending I should stick with the dealer service department--if they prove to be good, that is? So far, they have been good. We'll see what happens today.I'd build up a good relationship with a Mazda dealer if I don't want to DIY on my vehicle. Of course the service department of the dealer has to have good reviews. Although it can be more expensive than building up a good relationship with an independent garage, but overall you should get better quality of service with OEM parts, and good knowledge on your Mazda vehicles with technical support from Mazda North American Operations.
Confirmation Code: XXXXXXXXXX
Date and Time: 07/25/2018 02:40 PM
Service Advisor: Mazda Manager
Vehicle: 2018 MAZDA CX-5
Repair Services: 5,000 MILE SERVICE - PERFORM 5,000 MILE SERVICE INTERVAL
PERFORM OIL CHANGE SERVICE PERFORM TIRE ROTATION PERFORM BRAKE INSPECTION
INSPECT BRAKE LINING AND ROTORS INSPECT CHARGING SYSTEM INSPECT/ADJUST AIR PRESSURE
TOP OFF FLUIDS EXCEPT BRAKE FLUID
Notes: APPT. YY, WAITER, QUOTED $139.88
Requested Arrangement: Waiting while work is being performed
$139.88 for *5,000-Mile Service* is a bit high comparing to my Mazda dealer. My dealer charges $60 for oil change with Castrol oil, $70 with Mazda moly oil. One way to save money doing the service at dealers is you don*t ask for *5,000-Mile Service*, but rather, you ask for *Oil Change***Tire Rotation* specifically according to the maintenance schedule outlined in your owner*s manual. In the mean time you can ask them checking other fluids and tire pressure verbally. Of course you still need to know some basics of checking coolant*brake*etc. fluid levels and ask them to top off if you see any of them low. Go to dealer or Mazda USA*s website to find discount coupons on service.I don't get a message, if that's what you're asking? No blinking light, no nothing.
By the way, this is what they'll do today:
Code:Confirmation Code: XXXXXXXXXX Date and Time: 07/25/2018 02:40 PM Service Advisor: Mazda Manager Vehicle: 2018 MAZDA CX-5 Repair Services: 5,000 MILE SERVICE - PERFORM 5,000 MILE SERVICE INTERVAL PERFORM OIL CHANGE SERVICE PERFORM TIRE ROTATION PERFORM BRAKE INSPECTION INSPECT BRAKE LINING AND ROTORS INSPECT CHARGING SYSTEM INSPECT/ADJUST AIR PRESSURE TOP OFF FLUIDS EXCEPT BRAKE FLUID Notes: APPT. YY, WAITER, QUOTED $139.88 Requested Arrangement: Waiting while work is being performed
I'll keep you guys posted on how it goes.
Thanks.
Firstly, go to your "Vehicle Status Monitor" under *Applications* in your infotainment screen and select "Maintenance* to display the maintenance list. Check if you have "Flexible" setting under "Oil Change" which is supposed to be the default from factory. You can use the miles left on your oil life as a guideline for your first oil change. Follow the "Flexible" oil change interval which is up to 7,500 miles (10,000 miles for 2016(.5) CX-5) or 12 months whichever comes first. You can take your CX-5 in based on "Oil chang due" message with a wrench indicator from your "Flexible" oil change monitor, or do it early before the message displayed as your like. I'd keep the moly-rich factory oil in there for at least 5,000 miles within a year and do the first oil change.
