First Drive: 2009 Mazda 6
mikeyb
Contributor
01 BMW 325xi Touring
Bigger, Stronger and the Most Fun You Can Have in a Family Sedan
Car companies don't admit mistakes, but Hiroshi Kajiyama doesn't have a problem fessing up to a few missteps. He's the chief program engineer for the forthcoming 2009 Mazda 6 and although his English isn't perfect, it's clear he knows the current car has problems.
Weak engines, a tight backseat and a dull interior were all on his fix-it list. He talks to us about maintaining plenty of zoom-zoom in the new car, and of course, an exciting exterior design wouldn't hurt either. "We sought an exterior design capable of stirring emotions and distinguishing the Mazda 6 from the competition. We also strived to achieve a character that encourages a strong level of interaction with the driver," says Kajiyama.
He'll need all those things to make the 2009 Mazda 6 a success. Sales of the Mazda 6/626 have stagnated at roughly 80,000 units for more than a decade. Over the same time period, the Hyundai Sonata and Nissan Altima have come out of nowhere to pass it by. Mazda is aiming for over 100,000 yearly sales this time around. Here's what Kajiyama and his team did to make it happen.
Make It Bigger
Unlike the current-generation model, the 2009 Mazda 6 that goes on sale here later this summer is unique to North America. And like so many things that are uniquely American, the 2009 Mazda 6 is bigger in almost every dimension than its European and Japanese counterparts.
At 193.7 inches long and 72.4 inches wide, the 2009 Mazda 6 is larger than a Toyota Camry, yet smaller than a Honda Accord. The Mazda's 109.8-inch wheelbase is within an inch of the Nissan Altima and considerably shorter than both the Accord and the Chevrolet Malibu.
All those extra inches add up to a far more spacious interior than the current model. The Mazda 6 now gives rear passengers more leg-, shoulder and hiproom than the Accord, Altima and Malibu. Only the Toyota Camry offers more room in back and it's not by much.
Add Some Power
Super-sizing the Mazda 6 means more weight, of course. In this case, the Mazda 6 with the four-cylinder engine packs an extra 141 pounds, while the V6 model adds 169 pounds. That adds up to 3,547 pounds with the V6 in place — about average for the class.
To compensate, Mazda did the American thing and upped the displacement of both the base four-cylinder engine and the top-of-the-line V6. With 170 horsepower and 167 pound-feet of torque, the slightly larger 2.5-liter inline-4 no longer gets roasted by its peers. Along with its bump in displacement from 2.3 liters, the four-cylinder features a new two-stage intake, more efficient cylinder head and a less restrictive exhaust manifold.
When connected to the standard six-speed manual, the Mazda 6 with the four-cylinder delivers 21 mpg city and 29 mpg highway. Switch to the five-speed automatic and the Mazda 6 returns 1 extra mpg in the city and on the highway.
If $4-a-gallon gas doesn't faze you, the 3.7-liter V6 delivers 272 hp and 269 lb-ft of torque. These are class-leading numbers, but the fuel mileage figures drop to 17 mpg city/25 mpg highway, similar to the Chevrolet Malibu V6 (17 mpg/26 mpg) and significantly less than the Honda Accord V6 (19 mpg/29 mpg). A six-speed automatic is the only available transmission for the V6, and every Mazda 6 sends its power to the front wheels.
The Payoff on the Road
First we drive a Mazda 6 with the four-cylinder engine and an automatic transmission, and the extra weight of the bigger chassis doesn't drag it down. There's plenty of midrange torque and a smooth, refined feel near the 6,200-rpm redline. For anyone but the truly power-hungry, the 2.5 is plenty of motor for day-to-day driving.
There's no sport shift program for the automatic, but there's no need for one. Kajiyama says that the U.S.-specification transmissions were recalibrated to take advantage of the extra torque generated by the larger engines we get here. Downshifts come easily and upshifts are quick. A manual gate is there if you want to choose your own gears.
We drive a four-cylinder car equipped with the six-speed manual and it's just as enjoyable. The clutch take-up is easy to modulate and the shift lever notches from gate to gate cleanly. Then again, with poorer EPA mileage numbers than the automatic, the case for buying the manual transmission is pretty weak.
We expect some torque steer from the V6-powered model and feel almost nothing. Not bad considering how strongly it pulls away from a stop. Along with all the extra power, the V6 also sounds a bit quieter than the admittedly unobtrusive four-cylinder. Kajiyama tells us that all V6-powered cars get an extra layer of insulation at each corner of the bumpers and under the rear seat. It makes a noticeable difference, certainly enough for Mazda to consider adding it to the base models if costs allow.
Didn't Change the Good Stuff
One element of the Mazda 6 that hasn't changed is the way it communicates with the driver. The lively feel of the current-generation Mazda 6 has been one of the few reasons to consider it over the competition, and none of that responsiveness has been lost.
The steering is lightly weighted, yet the feel of the pavement still filters through the three-spoke steering wheel. Strong, easily modulated brakes and a tightly controlled suspension allow you to push the Mazda 6 hard before surpassing its modest handling limits. It feels like an Audi A6 that's had several hundred pounds removed.
Base models get 16-inch wheels and tires, but the upgraded Touring and Grand Touring versions of the four-cylinder "i" model are upgraded with 17-inch wheels and 215/55R17 rubber at each corner. The base V6 has the same 17-inch setup, while top-of-the-line V6s get 18-inch wheels and 235/45R17 tires.
Less Interior Shine Is a Good Thing
Quality is a theme Kajiyama repeats often. Sometimes he's referring to the sound of the engines, while other times it's the feel of the interior. The effort has paid off, as the new cabin looks and feels like a top-tier midsize sedan.
Unlike the cheap-looking design of the old 6 with its metallic trim, the new cabin goes easy on the metal accents in favor of a starker, almost Germanic look. Yeah, it's a little on the dark side, but the quality of the materials and clean overall design keep it inviting.
Simple features like the continued use of a three-dial climate control system and large, easy-to-read analog gauges are a welcome sight. The steering wheel is just the right size, and the seats have a good range of adjustment. Even the optional navigation system is fairly simple to use and adds little to the dashboard clutter. The layout is less confusing than the Accord and more visually appealing than the Camry's odd attempts to look fashionable.
With the driver seat adjusted to suit a 6-footer up front, we're more than comfortable sitting in back. There's plenty of knee room, decent toe room and ample headroom despite the sloping C-pillars. At 16.6 cubic feet, the trunk offers the most room in the class and its cleverly mounted support struts don't intrude on the space either.
Consider It Fixed
So with all of its major flaws corrected, the 2009 Mazda 6 now sits squarely in the middle of the midsize family sedan segment. It's no longer the sedan to buy just to be different, although its appealing shape still counts for something in a class dominated by soulless styling.
Going bigger and heavier usually means stripping away any notion of agility, but the Mazda 6 remains closer to a sport sedan than any of its competitors. Throw in an expected starting price of just over $19,000 for the base four-cylinder and the Mazda 6 competes well on the value scale, too.
It's a solid overall package with few faults. The next time Kajiyama introduces a new Mazda 6, he won't have to admit to mistakes on the old one.
"Weak engines, a tight backseat and a dull interior were all on his fix-it list"
I have to disagree with all 3 of these things as weaknesses of the 1st gen. Engines are plenty strong. The backseat is more than adequate. Is it really necessary to compete with a 7-series for backseat room? The interior is attractive and functional - not dull at all.
My fix-it list would have been:
"Trim excess body fat and tighten suspension." If you really need more power, supercharge the smaller V6.
Glad to hear they haven't turned it into a complete Camry, and have retained some sportiness to the feel.
Am I the only one who sees the problem here?:p
nah, not a problem... you just gotta really stretch the tire to get it on there ;)
My fix list would be to add more bodystyles to the mix so it appeals to more buyers. Have the top of the range engine the new TT V6 that the Taurus and Fusion will be getting.
Driving Impression: 2009 Mazda6
With its crisp new look, refined interior and composed ride quality, available luxury amenities and quiet cabin, Mazda's all-new 6 sedan is a poor man's Lexus.
Although the new 6 is about 6 in. longer and 2.3 in. wider than its predecessor, the handsome 4-door doesn't look any bigger. The new size translates to a 10-percent-larger trunk and 6-percent-larger passenger compartment, making it the new class leader in these areas.
The basic 4-cylinder-equipped model is a lot of car for the money at $19,100. Its 2.5-liter engine performs admirably, making 170 horsepower and 167 lb.-ft. of torque, shifts smoothly (we only sampled cars equipped with the optional 5-speed automatic transmission and not the 6-speed manual), and gets a very respectable 22 mpg city/30 highway (the manual gets 21/29, respectively). The 3.7-liter V-6 makes a full 272 bhp and earns mileage figures of 17/25 in its automatic transmission-only configuration; it starts at $24,400, which includes a much broader standard equipment package. Both the 4- and 6-cylinder engines run on lower-cost regular unleaded gasoline, a welcome bit of engineering in these cost-conscious times.
On the safety front, traction control, stability control, ABS with electronic brakeforce distribution, tire-pressure monitoring and six airbags all come standard.
Numerous upscale options are available, including a DVD-based navigation system ($2000) and packaged together a power sunroof and a sensational sounding 333-watt, 10-speaker-plus-subwoofer sound system by Bose for $1800.
What's Hot:
  • Affordable luxury
  • Quality interior
  • Engines run on regular unleaded
What's Not:
  • 4-cylinder a tad noisy under hard acceleration
  • Front fender styling awkward-looking to some
Cars to Compare:
  • Chevrolet Malibu
  • Toyota Camry
  • Honda Accord
-0 Road & Track
eh.. not feeling the snowflake rims
But.. i gotta say, it is good looking ride.
Where is mazdaspeed version damnit lol
What? No stick for the V6? Man I'm really glad I bought my MS6 then.
we can't get the JDM because the New 6 is a NA CAR ONLY! we're the only smucks on the planet in the face of 4 dollar gas want a BIGGER THIRSTIER car...good god almighty we're stupid people...i'm glad im german and not american
Better tell BMW M division, AMG, BRABUS and Audi S Division to cut the V8's and V12's and get with the 4cyl routine. Obviously, all those guys are morons as well.
While we're at it. Restrict the autobahn universally to 55mph. No more unlimited speed/polluting zones.
POWNED! LOL. Even the Mini gets horrible gas mileage for its size. It is 1/2 the size of the new 6 and only gets like 30-32 highway.
Theres a difference between those and a mass production large scale product like the mazda6. I turn a blind eye to micro exclusive cars like the racing divisions of euro luxury brands.
as for the mini, my friend's mini S gets 38mpg avg on a tank...
So the twin turbo BMW 335, the Merc S550 & E550, and Audi A6 4.2 FSI are "micro exclusive cars"?
Face it, the Germans love big horsepower just as much if not more than the Americans do.
They are not giving up their gas guzzlers anytime soon.
As fir the 38mpg average your friend gets, we must ride in the slipstream of 18 wheelers or something, or never spool up the turbo. If it's true, I'm impressed.
(dunno) I have been and driven in Germany several times. Yes, like on any other Country there are big horsepower junkies there as well but in average I see many more gas guzzler, huge HP, cars here than there. They are also home to great car manufacturers, but i.e. the Cayenne is mostly for export I believe.
The majority of the cars you see are compacts (hatchbacks are the favorites i.e. Nissan Micra, VW Fox, VW Polo...) with very "small" engines and/or diesel. My in-law loves cars and currently drives a nice BMW5 wagon, but is diesel.
As for the no speed limit in the autobahn is kind of funny, there are many "areas" where you can do pedal-to-the-metal, but with the traffic is almost impossible, serious. The majority of the time the speed is just like here or worse...
Similar Threads and Articles
