trufanatic
- 2008 Red MS3
What and where is the most accessible gromit for access thru the firewall?
or you could take off your glove box, and there's a hole there through the firewall as well
As much as i dont want to thats what i'll have to do, i need to clean up my wires and bad.
Kingston JA huh? How yard mi fren? i miss it down there, i miss that vr-4 galant i use to own the most
yea boss, wah gwaan
yow you going heading to the mazda winter palooza ting on sunday?
i do all of my wiring through the hole to the engine bay for the wiring harnesses, behind the glove box. the side kick panel is 1 plastic quick release clip, and the glove box is 3 screws and its out.
Later that same day, I drilled a 1/8" hole through the firewall below and to the right of the PJB harness feed-thru. I ran my single 18GA wire and sealed it in place with RTV. I found the hood release cable feed-thru to be pretty impossible to reach behind the ABS pump and I did not want to remove the upper dash for this project.
